| | | Forums66 Topics128,042 Posts1,055,520 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#55820 01/31/2006 5:32 PM | Joined: May 2000 Posts: 424 Shop Shark | | Shop Shark Joined: May 2000 Posts: 424 | I would say the pad is 1/8" or so. You can shim more there if it makes the front sheetmetal fit any better. The bolts are just (2) carriage bolts that drop in from the top. If I remember right, there's usually a small rectangular steel plate on the bottom with a couple tabs you can bend over to lock the nuts in place. I don't remember springs being used here, only on the cab. | | |
