Nice to meet you Trevor. If the battery is fully charged, and the fuel hasn't gotten old and gummed up the fuel system, the process is simple.
Put your left foot on the brake pedal and put the transmission in neutral. Turn the key on, pull the choke knob out, and pump the gas pedal twice. Then you push down on the starter button. Sometimes you will need to pump the gas pedal with your right heel while your right toe is holding the starter button down.
Pictures should be downloaded to another site such as photobucket, and then you post a link to your photos here. That process can be found in the Stovebolt Forum Operators Manual.(the yellow square at the top right of the forums page)
Enjoy your time at the 'bolt.
