| | | Forums66 Topics128,080 Posts1,056,315 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2009 Posts: 159 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 159 | I am putting together a 1965 292ci to put in my '50. I got to the connecting rod bearings and my book says to make sure the oiling hole is pointed toward the camshaft. I assume this is just an oil hole for the connecting rod bearing that gets it oil from the momentum of the rotating crankshaft dipping in the oil.
My problem is that the Clevite rod bearings I got don't have a notch in them that matches up with the oiling hole in the connecting rod. The original bearings had the notch in them. Do I need the notch? If so should I file them in? I don't want to fry my engine over something so simple (I'd rather fry it over something complicated! Any help would be great!
Thanks, Craig
It is neither wealth nor splendor, but tranquility in occupation which brings happiness. - Thomas Jefferson
CK
