The window seals that I got from Jim Carter and Chevy Duty (now Classic parts) were quite tight but they have loosened up nicely (no rattling and easy movement).
If you plan to paint your vehicle in the future, be careful using silicone lubricant. It is a substance that is hard to clean away and even a minute residue will contaminate most high-quality modern paints (and painting areas).
Tim
