| | | Forums66 Topics128,021 Posts1,055,354 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2000 Posts: 31 'Bolter | | 'Bolter Joined: May 2000 Posts: 31 | In the immortal words of Dr. Frankenstein
IT'S ALIVE!!!!!!!!!!!!!
Thanks to everyone for your suggestions. I did them all and as a result the truck started right up. I don't know which one fixed it but the end result is all that matters.
Here's what I did in case someone else has the same experience:
- Added a large ground cable from the engine to the frame. - Added a body ground wire from the negative battery cable. Cleaned and refastened the end bolted to the engine block. - Removed, inspected, cleaned and reinstalled the complete ignition circuit wire harness in the engine compartment. Sanded down all the terminal ends and added dielectric grease to all connections. - Regapped the points and checked all connections in the distributor. - Said a small prayer then swung a dead chicken over my head counterclockwise while standing on one foot and whistling the theme to The Dukes of Hazzard. - Put the key in the ignition and fired it right up.
I personally think it was the chicken ritual that made it work.
Thanks again to everyone.
BigMac Thanks Dan | | | |
Entire Thread
HELP, HELP ,HELP it won't start
| BigMac | 07/03/2002 11:18 PM |
Re: HELP, HELP ,HELP it won't start
| gmc248 | 07/03/2002 11:43 PM |
| BigMac | 07/04/2002 3:11 AM |
| Oly | 07/04/2002 4:20 AM |
| Curly | 07/04/2002 4:29 AM |
| GLPerry | 07/04/2002 6:29 AM |
| slomoe | 07/04/2002 4:19 PM |
| BigMac | 07/04/2002 6:40 PM |
| Mechainiac | 07/04/2002 10:11 PM |
| chiphead | 07/05/2002 1:56 PM | |
