Hello,
It's been 4 years since I started my 55.2 Chevy restoration and never thought I would see the day that I ask these questions.
1. I plan on using POR-15 and Bher black exterior enamel on my white oak boards. After applying the POR-15 do you scuff or use the POR-15 etch primer before applying the Bher paint?
2. I'm looking for opinions on this one. What do you think about painting the entire interior of the bed sides with bed liner? This isn't a show truck and will be used for dump and Home Depot runs. I don't want it to look strange, but I don't want scratched up bed sides either. The truck will be bright corvette yellow if that helps.
3. I have the box and all the boards on the frame with all the strips in and bolts in. How do I go about drilling the main anchor holes? I thought about drilling up from the bottom with a relatively small bit to locate the hole, then go to the top and drill the offset hole, then enlarge the bolt hole as necessary. Not sure if there are frame cross members in the way.
Thanks for your help!
Michael
