| | | Forums66 Topics128,135 Posts1,056,422 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | seeing as that you are in yellow pine country that is what I would go with. It is denser than white pine though a little more forgiving than w/oak. if your going to use oak then you may as well use a steel or aluminum block. all the newer gms use a steel shim betwee the box and frame. if you use wood over size the hole a hair so that it allows for shrinkage and won't vind on the bolt and split ron | | |
