Hello all,
ok, got 3 wires (after market harness) gong to the tail lights, with one individual wire attached to those three.
After messing around trying to get a better ground, it still did not work so I decided to move the blinker around to see if it works and then the one that was working went out.
If the blinker is dysfunctional, will it have any effect on the tail lights being on when they are not in blink mode?
Also, I am trying to make sense of that fourth wire. There are three that plug into one another, and then there is an extra one along side the 3 that plugs right into another single one that comes from the driver side tail light. I was thinking that the single wire might be for a license light but then why would it have another single wire to plug into?
Anyway, I hope this makes sense. Thanks for any help you might have!
Shane
Warrensburg, MO
