I have a 1941 GMC truck, Series 300 with a 248 engine in it, 1.5 to 2 ton dump truck, 5 lug front and rear that has split rim wheels on it. The split rim ring stamp says 20 by 7. What size tires would you recommend for it as it will be a hobby truck not for commercial use?
It has a wood hydraulic ram set-up for the dump, what do you recommend as far as hydraulic fluid for the ram?
