| | | Forums66 Topics128,075 Posts1,055,918 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#55029 01/16/2006 8:22 AM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | My Honda uses 5w-20 in the crankcase and 10w-40 in the transmission. It's like water. The VTEC doesn't work right without it.
216's were supposed to use SAE20 oil, I wonder how well 5w-20 would work in one?
I suspect other than a bit of extra lifter noise and slightly low oil pressure a 235 will be fine. The main bearings are so big they probably will be fine. You may burn or leak more of it though.
