| | | Forums66 Topics128,108 Posts1,056,236 Members48,437 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#54555 01/05/2006 5:18 PM | Joined: Jul 2005 Posts: 135 Member | | Member Joined: Jul 2005 Posts: 135 | Black smoke usually indicates that an engine if over fueling.
Perhaps a compression test is one of the first things that should be done. Remember to do this with the throttle wide open.
If you remove the carb for rebuilding why not go ahead and install a manifold gasket set. Easily done and can really make a differce in idling if there are leaks.
My opinion, if the compression is good rebuild the carb, put in gaskets, then use a vacuum gauge to seek some more on what is going on. A vacuum test can reveal valve problems, etc.
Word hard, play harder, enjoy life!
