2 members (RLB, 51 3804),
126
3
Mod | | | Forums66 Topics128,266 Posts1,058,386 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | easiest is to remove the glass, with attached lower sash and take it to the glass shop for them to use as a pattern to replace it for you so all you have to do is re-install it  start with the shop manual instructions .... the whole assembly needs to be removed from the door to replace glass - yes, the glass is "glued" in the channel with special glass setting tape/compound your local glass shop knows how to deal with Bill | | |
