I have a 1951 2 Ton 6100SW Dump. I'm trying to replace the drivers side door window which is broken. Door has vent glass too. Well I took the side cover off to see inside and what I have is glass resting in a metal channel. The channel has no screws on it to loosen. I'm thinking the glass is glued somehow in the channel. What steps should I take from here. Thanks
