The only concern with the SM-420 is the bolt holes in the mounting ears.
SM-420 mounting ears
The Chevy V-8 truck bellhousing from '55 up (not including the ones around '62 with the hydraulic clutch) looks like this:
\'55 up truck V8 bellhousing
I ran a '69 350 in my '49 half ton with this bellhousing. I had also used a '54 crossmember which bolts to this bellhousing in the '49 frame.
Notice the upper mounting holes are tapped while the lower ones are drilled to match the SM-420.
I see these bellhousings on ebay frequently listed as Corvette items. Easiest thing to spot is the reinforcing ribs above the upper trans mounting holes.
'38 Chevy 1-1/2 ton
'49 Chevy 1/2 ton
'54 Chevy 6400 2 ton
'55.2 GMC 3/4 ton
'56 GMC 1-ton
No Room Left in Shop
