1 members (Nick in Manitou),
70
3
Mod | | | Forums66 Topics128,026 Posts1,055,408 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#54330 01/03/2006 10:54 PM | Joined: Jul 2005 Posts: 5 Junior Member | | Junior Member Joined: Jul 2005 Posts: 5 | You may be off by one tooth. If it runs better when you turn the distributor housing one way or the other and you get to the point where you no longer can move the housing you need to carefully pull the distributor. Move the rotor/distributor shaft one tooth in the direction opposite of the direction you turned the housing and it should smooth out. This should get you close enough to set the timing. | | |
