They are probably the same. You really can't buy a clutch till you take the old one out. There are a lot of variations & options. Take the old one out & compare them. Then go from there. I know a guy likes to have the parts setting there but clutches are one thing it's best to pull it first. Sometimes the replacement is a newer style then the old one, but if it is the same dia. & you have the complete kit, it will work.
Last edited by Wrenchbender Ret.; 06/01/2009 10:06 PM. Reason: Thought of something else.
