Straight bolt in!!
There are some bolts just below the master that have shoulders on them that you will need to grind slightly or the flanges on the master won't sit flush on the firewall.
Just took the truck for a drive around the block and the brakes work well- other than they're 4 wheel manual drums. A little more stopping distance than my 07 Liberty with 4 wheel discs!
