i put new outer axle bearings and seals on but the small, 2" x 1/8" steel pin(I'm guessing on the dimensions as someone substituted a drill bit for the pin) that goes into the bigger steel pin (looks like a king pin) that goes through the square block of steel that holds the spider gears in place, is broken! i can't get the old drill bit out as its in pieces, but even worse, i don't know where to get a new one or even the proper dimensions of what I need to buy to replace it. if anyone knows the dimensions of the steel pin, that'd help a lot. also if you know where i can find one, that'd be great too. tony
Overland Blue, 1953 GMC 1/2T, 100-22, 228/1bbl, 4sp/4.10 6v, shortbed/fender side/5-window.
