| | | Forums66 Topics128,013 Posts1,055,312 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#54171 12/30/2005 3:17 AM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Only way that I can think of is if the crankcase pressure is higher than the fuel pressure, which is not likely. Check the PCV valve by shaking it lengthwise. If it doesn't rattle, it's stuck and needs cleaned or replaced.
Fred 52 3600 69 C-10
