| | | Forums66 Topics128,021 Posts1,055,355 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I've used the cork sides and rubber half circle pieces. The little tabs on the ends of the rubber help fill the gap between the oil pan and the cork gaskets, shouldn't have to trim anything. I do use a generous amount of silicone on those corners, otherwise I despise silicone gasket stuff. Use some contact adhesive to stick the gaskets to the oil pan, and Permatex #2 for pan gasket to block.
I bet everyone has a different method, this is what's worked for me.
Grigg | | |
