I did the swap on my 65 shortbed last winter. Check this link: https://www.stovebolt.com/ubbthreads/ubbthreads.php?ubb=showflat&Number=492803#Post492803
and check my webshots http://community.webshots.com/user/lakeroadster
The problem with the higher capacity tanks is they hang down real low. That why I used a 15 gallon chevy passenger car tank.
I am a Design Engineer and enjoy the challenge of things like this. If you go to my webshots link I have some drawings I made of the gast tank arrangement I utilized on my truck as well as pictures of the install / fabrications. Do you have any pictures of the frame area behind the rear axleon your truck? I would like to see the space constraints, maybe we can figure something out?
Thanks and IMHO you are making the right decision in relocating the tank out of the cab.
