8 members (Tyler Watts, Hotrod Lincoln, Joe H, Gray_Ghost, Forty9, cmayna, JW51, NJC),
82
Mod | | | Forums66 Topics128,064 Posts1,055,860 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2009 Posts: 9 New Guy | | New Guy Joined: May 2009 Posts: 9 | Hello, I'm new. I just bought a 66 C-60. The previous owner recently put a new master cylinder on, the old one was leaking. He bled and adjusted the brakes. But you have to pump the brakes 3 times to get a good pedal. When you do this you get a good firm pedal and the truck stops good. The previous owner pumped about 2 gallons of brake fluid through the system trying to solve this problem. I have checked his work and find nothing wrong. What do I try now? Thanks | | |
