Mnsmith, you have a point. I will be asking the same questions,as i will be putting in a open drive-line in my 1951 chevy 1/2 ton.
Something that i always wanted to know is why did gm install the torque tube rear-end off center of the rear fenders ? You can look at any torque tube truck, and the wheels are not centered in the fenders, why ?
I have a rear-end out of an 1967-1969 camaro, that is suppose to fit right in, we'll see when i get to that point.I'm curious if it will be off center ?
It sounds like gm solved this problem with there 2nd series 1955 trucks with open drive-line.
As far as the searches for past articles, I wonder if you get all related articles involved with your search ?
Thanks, Tim
1951 3100 Chevrolet
