9 members (Peggy M, dt235sd, 50Chevy3100, klhansen, Hush, Charles in CA, Nick in Manitou, 41 chev, 1 invisible),
344
Mod | | | Forums66 Topics128,270 Posts1,058,408 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | It's up to you, without seeing the frame its hard to make that call. Chances are that the stuff under the cab and greasy engine are OK, it's just the tail end out in the weather that got rusty.
I'd be a little hesitant to replace the rivets with bolts though. Be best to re rivet everything back together. If you do use bolts use flanged frame bolts and the flanged self locking nuts. Most big truck and trailer parts places have or can get them, and they are not real cheap.
Grigg | | |
