1 members (Hotrod Lincoln),
104
2
Mod | | | Forums66 Topics128,089 Posts1,056,004 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2008 Posts: 13 New Guy | | New Guy Joined: Feb 2008 Posts: 13 | Thanks Mike, I took the master cylinder off and completely disassembled it and then I bead blasted the housing and cleaned all the seals and springs and whatnot. Now I have a master cylinder that looks brand new and also works like it too. But the pedal is still staying down so I guess Ill have to look at the pivot point on that as Im sure it is rusted up and sticking as well. I dont think the master cylinder piston was sticking before as I had very little free play when I would pull the pedal up manually but I knew that it could use a good cleaning anyway. | | |
