| | | Forums66 Topics128,088 Posts1,056,124 Members48,435 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2002 Posts: 2,254 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,254 | I don't know how to respond. I will give it a shot.
I had this problem with my 55 2nd after I replaced my cab mounting bolts and had the engine rebuilt. I bent that rod every which way and it would not fit my gas pedal. It would always get hung up. I would think the angle or round bend should be just a little more. And times it should come into the body at a different angle.
Luckily. I had 3 rods and 2 gas pedals. I finally got an un-bent rod and a gas pedal to work. I believe that my 2 gas pedals had the backside 'pop in' hole in just a little different spot. And the rod needed to be original and not modified like I was believing it should be.
My 55 2nd works well and runs great.
I hope this helps.
Dennis -there is nothing stronger than the heart of a volunteer-
