| | | Forums66 Topics128,268 Posts1,058,375 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2008 Posts: 360 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 360 | the adaptor plate picks the water pump up into the position it would have been in an earlier truck w/ a 216 motor. i am using one on a 261 build that i am putting in a 46 1/2 ton. i believe the pump you are looking for is a 53-54 w/a 3/8 pulley #3836084. this pump is available in a modern build through napa and rock auto. double check the pump # as i dont have my books w/ me right now.
making a short shaft pump requires pushing the shaft throught he pump body and grinding off the hardened shaft to the correct length. try searching using the pump # abaove or w/ key words such as shortened pump or water pump clearance, short shaft water pump.
big ed
"it's only old if you can't find a use for it; otherwise it's cool and i'll use it."
