Dome Light……What dome light. According to the owner’s manual there wasn’t one. That switch near the ashtray under the dash is a 3 position switch powered when the head lights are on. Left is the dash gauge lights, center is no lights, and right is a light behind those openings in the center of the dash to sorta illuminated the ignition, choke, and throttle plus enough to read a map
