| | | Forums66 Topics128,057 Posts1,055,814 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2000 Posts: 1,966 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,966 | Last year I took the oil pan off of my 50 216 to do an internal inspection and replace the gaskets. I cleaned about 1/2" of deposited dirt and sludge out of the bottom. I cleaned and inspected as good as I could, repainted the outside and reinstalled with a new gasket. Almost immediately a pin hole shown up. I did what any self-respecting redneck might do - ran a sheet metal screw thru it. That almost stopped the leak. Later another pin hole. I made up a little JB Weld and covered the area where both holes are. First re-fill of oil (after replacement of pushrod cover and valve cover gaskets) and a 15 mile trip around the area and - you guessed it - another pin hole. Corrosion from old, dirty oil right? That old dirt was sealing the holes. Anybody else had this? Any remedy besides a replacement pan?
Professional Novice
