I think you can wire the straight blade fans to blow either way, but the curved blade fans, which are designed to cut the noise factor, will not work correctly when wired backwards. They will work, but they are very noisey.
"Truckin' Around .......... Since 1937!"
My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.
Operators are standing by to take your calls!
