0 members (),
104
Mod | | | Forums66 Topics128,266 Posts1,058,386 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#52665 11/20/2005 6:02 PM | Joined: Mar 2004 Posts: 71 Member | | Member Joined: Mar 2004 Posts: 71 | I had picked up a shudder under acceleration in my 49 1/2ton with 216.
I made the cardinal sin of doing two things before testing it out so I'm not sure which was the culprit.
I did find that the vacuum line fitting going into the carb wasn't completely tight but I also replaced the plugs which were starting to carbon up.
Question. When replacing the plugs, I noticed that the plug in cylinder 5 appeared to be fouled. Could a vacuum leak cause one plug to misfire?
Anyway, she is running fine again so hopefully I fixed the problem. Thanks to all. | | |
