7 members (LAROKE, Stovebolt48, Tronman, Bwana-Jim, Otto Skorzeny, Lightholder's Dad, 1 invisible),
72
3
Mod | | | Forums66 Topics128,042 Posts1,055,511 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#52664 11/25/2005 4:02 PM | Joined: Feb 2005 Posts: 469 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 469 | When you find your pictures and figure out how to put it back togeather dont use heavy grease to pack the needle bearings. Heavy grease will pulg the drain holes and wont let the tranny lube corectly. Use a light grease like vasoline. This will hold the bearings just as well and not plug the drain holes when the gear box is put into use. | | |
