| | | Forums66 Topics128,163 Posts1,057,044 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | There's a picture in the link below of the holes in the block and you would see the same thing on the head. They are 3/16" in diameter, 1 17/32" center to center and paired between cylinders 1&2, 3&4, and 5&6. I have coordinates of all the holes and if you need more data pm me and I can help you lay out the holes without a gasket. Can't help with the oil pan issue though. http://www.1954advance-design.com/Web%20images/261-engine/index.htm
1952 1300 Canadian 1/2 ton restomod You Tube | | |
