1 members (CuzzFuzz),
228
6
Mod | | | Forums66 Topics128,101 Posts1,056,181 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | | ZooKeeper Unregistered | | ZooKeeper Unregistered | Just swap out the ring & pinion in the 3rd member to a high gears. That's what a friend had done w/his 65 PU && you get to keep the lug pattern you already have. Or you might be able to swap your axles into the new rearend. I believe up to 72 will fit but I might be wrong on this part...Joe | | |
