| | | Forums66 Topics128,076 Posts1,055,922 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2008 Posts: 360 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 360 | heard the same tip as well. i was told that if you get the grease to dispense under enough pressure it will pop the bearing with out the ram rod, but i have heard of useing a tap rod as well. would assume wood is better than a hard steel as you are less likely to scratch anything.
ed
"it's only old if you can't find a use for it; otherwise it's cool and i'll use it."
