| | | Forums66 Topics128,036 Posts1,055,448 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2004 Posts: 322 'Bolter | | 'Bolter Joined: Dec 2004 Posts: 322 | I just saw that the new (1 yr old)fuel pump is leaking. I had a problem with this US made pump when I first bought it, the screws holding the top where not long enough and would not seal the rubber gasket. I replaced them with longer screws and problem solved. It is now leaking around the seal again even though the screws are tight. I did not put any lock-tight originally.Can I over-tighten these screws? Anything else that might cause this? Truck was last driven a couple of weeks ago.
Blue 50
1950 3100 w/57 235 Patrick’s Saginaw 4 speed and 3:55 rear end | | |
