Puting my truck back together (1950 GMC 100, Neg ground / 12v)and decided to tie my fuel sender and battery to the orginal fuel gauge last night. Since I converted to 12v I figuired I need a "voltage reducer" and had picked one up earlier from Classic Parts, part # 24-995. I thought I would verify the reducer by applying +12v to one lead, putting the + side of my meter to the other lead and finally taking the - probe of my meter to ground. Result = 12.5v...huh? Since there were no instructions I called the tech line at Classic today and they said that the so called voltage reducer is actually a current limiter and has no affect on voltage (funny, that sounds more like a fuse to me). Anyway, he said the term voltage reducer is just a name that stuck and that it is really the current that needs to be controlled in order to make the gauge work correctly and not burn up. He went on to say that this wires between the ignition side of the switch to the "empty" side of the gauge and the "full" side of the gauge ties to the sender. Looking to get a "nod of approval" from you guys before I walk down the path of no return.
Thanks!
Alex
PiLe dRiVeR 13
