| | | Forums66 Topics128,035 Posts1,055,557 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,760 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,760 | I buy Sunnen honing oil in 5-gallon lots for my valve grinder and rod hone, and swipe a little for cylinder honing. A good substitute is 30W motor oil and Varsol solvent (mineral spirits), in a 50/50 mix. HOT water, Tide, and lots of elbow grease with a scrub brush is the only way I know to get the residual grit out of the cylinders after honing. I once wore out a set of rings in 2500 miles, from a solvent cleanup after a honing job! Jerry
