8 members (kurbside bolter, tclederman, FAST55, Hotrod Lincoln, KEVINSKI, 1955 1 Series, Charles in CA, Otto Skorzeny),
153
2
Mod | | | Forums66 Topics128,267 Posts1,058,373 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2008 Posts: 493 Shop Shark | | Shop Shark Joined: Jan 2008 Posts: 493 | I repaired a small crack on my MGA with JB weld and ran it that way for 12 years of so. I swapped the block last summer and had the old one welded as a spare. I cleaned the weld and covered it with JB weld just for good measure. Make sure you clean it with a wire wheel or something to get all of the crud out. If it is in an area that you can work on without much trouble try it. If it doesn't work put the other motor in. | | |
