Hy John Milliman, it sounds to me like you have a sticking, burned, or too tightly adjusted intake valve. It may also be a broken valve spring on an intake valve, also extremely worn valve guides can cause this, or it could be as simple as a chunk of carbon holding a valve slightly off its seat, hope that helps.
