| | | Forums66 Topics128,154 Posts1,056,838 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,851 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,851 | Compare the size of the ports. If the 350 manifold has ports noticeably bigger then the 283 heads, a step will be created that makes for extreme turbulence in the head passages. You would need to port-match the heads to the manifold runners. Not a terribly difficult task, but there's a risk of hitting water or grinding through the head if you haven't done a port-match before. Jerry
