| | | Forums66 Topics128,162 Posts1,056,937 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#51583 10/28/2005 5:43 AM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | The valve cover gasket is the same for the 216, 235 and 261. Also, the 216 valve cover will fit the 235/261 if you replace two rocker bolts with the appropriate studs.
Fred 52 3600 69 C-10
