What type of trans do you want, an automatic or a different manual?
My 64 has ac and the ash tray is mounted under the dash just to the right side of the steering column. This may be the type of tray that you need?
1959 Apache 3200, Standard Cab, Big Window, Fleetside, 235/3spd, Original Paint
1964 C20 Standard Cab, Fleetside, 283/Power Glide, A/C, Pwr Steering, Pwr Brakes, NoSpin
