I am at a cross roads in my rebuild. I am sticking to the full driving mock up with a second teardown for finishes and final build.
With all the requirements for new rubber, gaskets, etc. I am in a quandry as to install now or wait until finished and install on final build. If so she will never really be in a driving mockup mode.
Dealing with items such as sway bar rubber, shackle and shock grommets, gaskets, seals, body mounts, engine/tranny mounts, on and on. If they remove to often they will need replacing.
What are your thoughts? How did you wokr this?
Brett
