| | | Forums66 Topics128,132 Posts1,056,386 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Mark53,
Did you have to pull the cap or wires or distributor to get the sidecover off? Did you adjust the intake and exhaust on the cylinder that had the pushrod off.
Just getting the cylinder back on line shouldn't have made it run worse provided you adjusted that valve properly. It sounds like you whacked something out of kilter when you pulled the sidecover. Does this sound possible? Were they solid lifters?
Stuart | | |
