| Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,792 | If you're using that much oil, the exhaust guides are worn out. Don't waste time changing seals; swap the head. Putting umbrella seals on would be a very short-term fix, if it workd at all. Jerry
