| | | Forums66 Topics128,157 Posts1,056,875 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2008 Posts: 32 Apprentice | | Apprentice Joined: Oct 2008 Posts: 32 | Yeah, should be the same. Just make sure all the bushings & balljoints are in good shape or replace them. Get the master & brake lines if you can. The lower A arm on the '82 has two Ubolts that bolt the round bushing bar to the crossmember. My '66 has 4 bolts that bolt a sorta flat bar to the crosmember. I had to drill out one hole on each end of the bar out to 9/16" and the other holes had to be re-drilled about 9/16" closer & out to 9/16". I hope this makes sense. It might be easier to swap out the lower bars if the '71 is round. Especially if you replace bushings. I don't know what the '71 looks like. Maybe you can just swap out spindles? I didn't check just swapping spindles, because my bushings & balljoints were good & I wanted to mount the swaybar. | | |
