8 members (Ponchogl, Peggy M, Gray_Ghost, David Bush, TooMany2count, Tronman, JW51, Wayne67vert),
94
2
Mod | | | Forums66 Topics128,052 Posts1,055,716 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#51205 10/16/2005 10:02 PM | Joined: Oct 2005 Posts: 29 'Bolter | | 'Bolter Joined: Oct 2005 Posts: 29 | I have a 1954 GMC 350 dump/flatbed with original 270. The exhaust manifold fits poorly; leaks with one combined intake port on cyls 2 & 3, and out exhaust port#4 despite new gasket & retorque @ 20ft-lbs middle studs and 30ft-lbs on outer studs. Is the manifold or head warped?
In the same vein, I have access to a rebuilt Chev 292 which is in near perfect shape, and with much less worn 4sp transmission. How hard would it be to fit this engine in the old GMC?
Thanks! | | |
