| | | Forums66 Topics128,195 Posts1,057,379 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,882 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,882 | I've watched the rebuilding process on several clutches, and the balancing procedure is the last thing that gets done after all the reconditioning and assembly is accomplished. At worst, the loss of that balance weight might create an annoying harmonic at a certain RPM, but it won't keep the clutch from functioning. Run it awhile, and see if it shakes too much to suit you. An inline six is naturally balanced, because of the even spacing between power strokes and the design of the crankshaft. It would take a pretty good bit of imbalance on the pressure plate to make things shake very much. Jerry
