Two of those casting numbers show up in a chart on this page . Those side cover and extension housing numbers appear to be from a Saginaw of '73-'75 vintage. I found another source that includes '76 for the extension housing (which was also used on the Saginaw 4-speeds). Your date codes suggest '76 as the year. I couldn't find your main case number.
Curt
1953 Chevy 6400, 1957 Chevy 2dr Sedan
--"Mediocrity is easy, the good things take time"
